D deacon49 May 14, 2012 #1 will it harm the engine running a 1.3 on a 1.0 ecu because looking into it the 1.3 transponder plug is different to the p reg 1.0 transponder so cannot plug the 1.3 transponder in to de imoblize the ecu to start the car thanks
sleeper_ss Ex. Club Member May 14, 2012 #2 Yes put the 1.3 in and away she goes. Use your 1.0 litre gearbox or you'll have to change the drive shafts
OP OP D deacon49 May 14, 2012 #3 cant de immobilize the 1.3 ecu because the tranponder plug is different on the 1.0 harness can i get a 1.3 non nats ecu plug it in and work ??
frank Club Member May 14, 2012 #4 deacon49 said: cant de immobilize the 1.3 ecu because the tranponder plug is different on the 1.0 harness can i get a 1.3 non nats ecu plug it in and work ?? Click to expand... no, they,re different pinouts, the 1.3 will run fine on the 1.0 ecu
OP OP D deacon49 May 14, 2012 #5 what do you mean different pinouts ive just purchased a 1.3 non nats ecu off ebay 50 quid :O will it not plug in and be fine
frank Club Member May 14, 2012 #6 deacon49 said: will it not plug in and be fine Click to expand... not without the non-nats loom, the wiring configuration is different
