O
ohc_turbo
firstly what ive done is put a 1.0 carb, manifold and everything onto a 1.2 block.
the car is running lumpy with flat spots and everything, firstly its a bit of a pig on cold startup but not that bad and then it idle's at 1500 untill lets say 20min of driving and it bogs down to 400-500 and stalls on deacelleration(comming up to traffic lights etc)
all the time its lumpy and when i rev it it gradually goes down and sometimes if i rev it to lets sat 3000 and let off it will climb up a bit more before it falls down - weird?
i can hear a hissing sound when im sitting in the cockpit, checked around the carb and everything seems connected, the crankcase ventilation pipe is a bit loose but this wouldnt do this, thinking of blocking that off anyway.
as far as im aware i transfered the carb without disconnecting anything, maybe the 1.0 carb isnt sutable for the 1.2?
help
help
