Loss of power when hot
CMF_Tony b
Perhaps someone can advise please. My daughters' 1993 1.0LX has developed a problem. OK when cold but drastic loss of power at mid rev range under load when hot. Diagnostic on ecu gives fault code 12 which is the airflow sensor. I've replaced the 10 amp fuse in the fuse box by the battery - this was overheated / corroded and cleaned the fuse holder. Plugs, leads , distributor cap / rotor arm have been changed as a matter of course. Last year the micra had the stalling problem and I followed the excellent guide on re-spldering which fixed the problem. Would another re - solder cure the latest problem or am I into a recon throttle body (or something else)?
