Tell me then...what parts came off a Pulsar?
Block...nope - Almera GTi
Crank...nope - Almera GTi
Rods...nope - Eagle (Aftermarket)
Pistons...nope - S14 200sx SR20DET engine
Gasket...nope - Cometic (Aftermarket)
Oil Pump...nope - S14 200sx SR20DET engine
Head Studs...nope - ARP (Aftermarket)
Mains Studs...nope - ARP (Aftermarket)
Crank Girdle...nope - P10 Primera eZX
Sump...nope - P10 Primera eZX
Cylinder Head...nope - P10 Primera eZX
Fuel Injectors...nope - S15 Silvia SR20DET engine
Wiring Loom...nope - part Almera GTi, part P10 Primera eZX, part K11 Micra L
MAF...nope - Z32 300zx TT
Camshafts...nope - JWT (aftermarket)
The list goes on and on.
The only items that have anything to do with a real Pulsar, i.e came off a Pulsar or were intended for a Pulsar were the ECU (Mine's unit i.e. aftermarket) and the throttle body (which is modified to fit anyways).
Look at it this way...
My Wife is an artist. If she takes the styles of Picasso and adds it to the one painting, does that make it a Picasso...nope.
CASE
SWEAR EVADING IS NOT TOLERATED CLOSED!!!
Sorry, but it gets to me when people say it is a Pulsar engine.
kristian said:
Have you read my thread on my conversion.. how would you rate the performance of mine off the top of your head..
est 1/4 mile, 0-60 time?
SR20DE Highport eGT block and box, standard internals,
Iridium plugs
P/S + W pumps removed
Blitz 0.9mm performance Ht leads,
4,2,1 mandrel bent Stainless manifold, 2.25'' outlet into full through system
CAI with K&N filter
225-45-14 Toyo's
700Kg
I would forget about the Blitz HT leads and then you will easily run into the 14's, provided you can get the car to launch. As for the 0-60...6's, maybe even 5's.
Dave
P.S. You also want to modify the header so the collector goes into a 2.5" section and then run a 2.5" system to the back. 2.25" looses power over the 2.5" on the SR20...proven fact!!!
