Thanks Frank, I have some unidentified yellow dampers here, therefore I think they may be Koni. They measure 59.5cm to tip but the important shoulder is 6cm down the shaft. The bottom bush is 14mm dia i.d and 40mm thick, the tube itself is 40mm o.d and the shaft dia is 12mm. IIRC that's right for a Micra - and that's why I thinks that's what they're made to fit. Can you confirm?
