and its best to shove some finebore rigid pipe into the rubber pipe, else it gushes out (mines driverside only, which would fail a mot i guess, but works fine)nice idea ill have to get longer pipe
like migwelder liner mate, 2mm bore......ishlike plastic vacuum pipe frank?
I've got a pair somewere Belly if you want them, only cost you the post i dont run a screen washi shall see whats lying around at work
if you dont mind pricing postage skinner, and what do you do if you end up with a dirtsy screen as your driving?I've got a pair somewere Belly if you want them, only cost you the post i dont run a screen wash
hangs out the window with a bottle of water and a rag
