grr Fed up with unlocking my bonnet jets!
This sounds lame but this is becoming silly.
I've completely flushed and cleaned the washer bottle. Removed pump and replaced and filled with clean water. Cleaned inside black rubber tubing, poked needle in jets and successfully get them to spray as wanted.
Then after two days, the jets are blocked again. Removing the tubing just before the jets shows a good flow so pump good.
Can anyone think why the jets keep blocking up?
Also, can the jets be disassembled? I've had them of the bonnet but cannot see an obvious way to take them apart.
Alternatively, does anyone have a couple of working jets they can sell me or somewhere you can buy them new?
(97)P reg 1lt K11 muzic, with no rear wiper.
thanks
Mark
thanks
Mark
