K11 dashboard dimensions
Low Rider
Poindexter
Founding Member
Moderator
Can someone with a K11 measure distances A & B in mm and post up the numbers?
A being the distance flat, (i.e. before the dash starts to curve upward).
B being the distance between the 2 ridges.
I could but visibility would be compromised. They will probably end up on the LHS corner of the dash pod, as that makes mounting and wiring easy, (obvious option to mount them on the a-pillar is no good due to the roll cage being in the way).
get rid of the standard clock suround,,,,,,,,,,,,custom a longer one up? to add the other gauges
i thought i see someone done that on here
Managed to find a dual oil temp / oil pressure gauge from SPA to go with the XC-16, so 2 will fit in there fine, (originally figured we'd need 3).
