K10 super S 1.2 its back again
Mark said:
nah there for grannys mate, you wanna get a K10 again
Don't knock 'em till you've tried em ;)
Getting one of these soon:
getImage.aspx
* Two bolts broken in Water Pump causing minor water leak.
* Bolt broken on Cam cover.
I bet that leak is more than minor. The bolts holding the water pump in aren't big, getting the snapped studs out will be hard, and the block would probably have to be helicoiled to sort it.
It's pretty hard to break one of the cam cover bolts, especially without damaging the cam cover. If it's not done up properly, the cam won't be fairing too well either.
Whatever the case, two problems like this suggest that someone who really doesn't know what they are doing has been working on the car. There will probably be a hundred other things wrong with if you look a bit deeper.
Micra buffs would probably know why this engine seems much quicker than the normal ones but fast it is.
What's that guy on? The Super S is pig slow. a 1.0LS is quicker on the road.
