intercooler hoses
i want it to look ok ish to tho :) but if it comes it ill take that advice thanks frank :), dont suppose you know the exact outlet diameter of the kp35 turbo i measure mine at roughly 30mm
Cheers guys and next one is alot of the ebay intercoolers are 57mm exits but the outlet for the tuby is about 30mm would i be better off using a couple of reducers or have a custom one made?
Boosting into larger pipework makes your turbo work harder to fill the wider gap. Try and stick to a minimal size :)
What stani said ;)
Radiators are designed to send the water through each pipe to get maximum cooling effect on water.
Intercoolers use larger inner core pipes to allow air to flow faster. Thats why they're generally thicker too making em less resistant to flow :)
Though I have seen a heater matrix as an intercooler
