my horn wont work, replaced the full horn checked fuse and checked for power at the connecter, all good there but it wont work. any ideas......... mot is next month
sonic said:is the horn earthed ?
magpie said:the super s my misses crashed is all mashed up at the front...................................horn still works though
paddymarsden said:just lean out the window and shout 'Honk Honk'
ralphc said:The horn in my girlfriends car isnt working. Its a 1995 1.0 micra. I have replaced it with a new one and no joy. Checked the fuse and thats ok. There was a mention of a Horn relay on this thread. Where is this located? Had a quick look under the bonnet and none of those mentioned the horn. I will check to see if its earthing properly tmrw. Car booked in for MOT in 2 days so I need to fix it. Might need to manually wire it up as suggested above. Any help would be much appreciated
ralphc said:Found some relays (additional to the ones under the bonnet). There were 4 of them to the right of the fuse box. Nothing to say what the relays were for though. pulled them out and swapped around but still no joy. There seems to be no power going to the horn switch (on the steering wheel). Got fed up after 5 hours! Went to halfords, bought a toggle switch and some cable and wired up the horn myself. It works now! Would have liked to have used the existing switch on the steering wheel but couldn't for the life of me find which wire went to the postive terminal (on the switch). Maybe that was the problem - a break between the steering column to the steering wheel. Oh well, hopefully it will pass the MOT now ;-)
