Joky Feb 20, 2014 #1 i have problem with my cliche .. my leg get tired ... its little hard to press »
r-reg-sr ------- Site Supporter Feb 20, 2014 #2 may need adjustment under battery is clutch cable-wire and can be adjusted. it is locked with 10mm nut
OP OP Joky Feb 20, 2014 #3 thanks alot ... i will check it r-reg-sr said: may need adjustment under battery is clutch cable-wire and can be adjusted. it is locked with 10mm nut Click to expand...
davyboy Feb 20, 2014 #4 Joky said: i have problem with my cliche .. my leg get tired ... its little hard to press » Click to expand... I thought that was a jokey from joky - not April 1st yet is it ?
