frank said:lol, stall it in gear karl have you trapped the alternator wire somehow ?
Belly93 said:Running on? Electrical problem more than likely. There isn't something. Earthing out some were is there
ignition switch maybe ?It will eventually stall itself but all the lights on the dash stay on unless I disconnect the battery
micra 2000 said:i know nothing about the tb's but is the wiring exactly the same for both, its just that if you have the ignition lights staying on with the keys removed it seems to me that you may have a permanent live going to something that should be ignition live this would then keep everything powered up,check a wiring diagram for the two parts
karlj said:Ok think I've found the culprit
The green relay...... Removed it, started the engine and it turned off as it should, put it back in and it starts just won't turn off again.
Is it safe to run without the relay?
