Help Please x
Hi there, any ideas? we have cleaned the throttle body with the carburretor cleaner as suggested in another post, but the tank is showing quarter of a tank of fuel, which is a bit dodgy from time too time anyway lol because the gauge has a mind of its own...now when i go to accelerate, it is like the engine is dying, but then out of nowhere it picks itself up again. Def know there is petrol in there mind......
any advice gratefully appreciated
XxX
It could be listed as the Air Flow Meter / Mass Air Flow Meter or words to that effect.
Im probably wrong like, i just know a dirty / faulty MAF gives a flat spot on acceleration
Or the fuel filter could be choked or drawing in air, had the same symptoms wen my fuel filter was mingin!
Never hurts to change the fuel filter for peace of mind but by the sounds of it, the throttle body could use the resoldering trick as well. Not a tough job, you just need patience when doing it. Done it on mine and it's worked a treat.
