Easiest thing to do MrMigs is get a multi meter and check for voltage. Get a friend to sit in the car to control the light switches.
For instance, turn on indicator switch. On the connector plug to the lights find one which is showing a 12v feed. Then match it the which wire goes to the bulb on the cluster . Do the same for the others
Hope it helps
