R RichardCo Feb 15, 2011 #1 My headlights are pointing at the moon! Im not sure how to adjust them so they are are the road. Any help?
SuluR Buy & Sell Member Feb 15, 2011 #2 for non electronic adjustmant there are a couple of screw like bolts which come out the top and bottom corners at the back of the headlights. if you tighten the top, iirc the light will shine out lower.
mullet Ex. Club Member Feb 15, 2011 #3 when adjusting the lights shine them against a wall and you can see howmuch they have adjusted
infinity Aug 28, 2014 #4 is there any way of adjusting the electronic adjustable headlights manually? Even on max setting my right hand side lamp is too low.
skymera Brutal Honesty Aug 28, 2014 #5 infinity said: is there any way of adjusting the electronic adjustable headlights manually? Even on max setting my right hand side lamp is too low. Click to expand... There should be a manual screw on the electronic adjuster behind the headlight
