Heater blower stopped working
Hi.
The other day the heater blower stopped working on all speeds, so I think I can rule out replacing the resistor card. I've heard there is a common fault with this type of Micra and that it could be a case of wiggling some wires/connection, just need to know which wires/connection and where it would be located on a 1999 1.0 Micra?? The backwindscreen heater is still working, but I'm guessing that is powered by something else.
If anyone could let me know where to look and what to try, I would be eternally grateful.
ps Do you have to allow the temp of the car to warm before the heater blowers work?
Joel
fuse maybe joel ? then you need to check if power is getting to the motor, and if not then check for power at the switch
