headlights
Alienfish360
Awesome Dawson
These headlights are driving me mad on the pre-facelift K11, anybody got a tip on how to get them off when the nut has rusted onto the bolt? it just spins :(
Have you tried soaking them in something like wd40 phil?? just to penetrate it? They do have two other mounting points at the front of the light so if in the worst case u had to break the bolt off u could always mount them without the rear bolts(Y).
if you take the other bolts out first, and push the h/lamp sideways (towards the wing) while turning the nut, it will work its way out of the retaining channel phil (then use 2 spanners to get the nut and bolt out after) :)
guys i have a problem its behind the headlight. its the front indicator, where the indicator bulb goes in that part has rusted and broken off. need some help of how to remove them 2 wires going in to it so i can remove it. please help me thanks
