W welsh_micra Dec 27, 2007 #1 im after the diagram and tightening torques for a 1.2 k10 i can find the thread on this anywhere thanks scott
Baz Ex. Club Member Dec 27, 2007 #2 welsh_micra said: im after the diagram and tightening torques for a 1.2 k10 i can find the thread on this anywhere thanks scott Click to expand... You'll find all that in a haynes manual . . .head bolt tightening sequene and torques
frank Club Member Dec 27, 2007 #3 welsh_micra 2 stage 25 to 29 then 43 to 47 lbf, starting from the middle
OP OP W welsh_micra Dec 27, 2007 #4 i dont have a haynes manual. has some1 got the sequence and what th e torque are in NM?
frank Club Member Dec 27, 2007 #5 welsh_micra only got lbf or kgf m sequence is,nt that important as long as you start in the middle and work outwards (either diagonal or circular will do) imo
ollie240585 Ex. Club Member Dec 27, 2007 #6 lbf to NM http://www.tiniusolsen.com/resource-center/lbf-n.html
W whipit Dec 27, 2007 #7 frank said: welsh_micra only got lbf or kgf m sequence is,nt that important as long as you start in the middle and work outwards (either diagonal or circular will do) imo Click to expand... Actually its extremely important if you dont want to snaap your head.
joesouthgate Super Moderator Moderator Club Member Dec 27, 2007 #8 yer if you dont do it properly you can destort your head! Ouch!
