As you know i've just had this conversion done, with the 200mm clutch.
You'll need a cg13 starter motor, and may have to change the drive shafts to, but not 100% on that as my ones were just from the Cg10.
Deff worth the conversion tho, i can get:
1st - 34
2nd - 63
3rd - 96
4th - off the clock (but at a push)
5th - ????
Thats with the cg10- ecu also, so infact it's not running right at that...
If i change to the 1.6 ecu and tb, i'd like to see the results.
0 - 60 times is about 8 secs ish, but not confirmed readings yet, but will maybe borrow Chies timer to get some readings.
