GA16DE micra.....
After a year of not having a micra im back! I brought a 2000 reg k11 with the head gone, which soon turned into a blown engine. So after not much thought i brought a Ga16 lump. Ive got the engine in there modified the flywheel, water pump, crank pulley and made a mount for the drivers side, so all i really have left it to, blank the egr off, make a almera radiator fit and plumb it in and wire it in, i do have 2 issues left though
Firstly does anyone know what to do about power steering, due to it being a bit cramped i cant put it back in the original place,
Secondly what throttle body should i use? The cg or ga?
Any help would be epicly appreciated!
praps get a 12v p/s pump from a peugeot/citroen etc maybe ? and the CG t/b will be more suited to the ecu and loom eh :)
I have considered the electric power steering, but ive made brackets and stuff before to mount pumps on so i may just stick it on the front,
I though the cg tb would be the one because of the loom so i'll see what it goes like with that one
