A Alessandro Club Member (Trial) Oct 9, 2007 #1 Hi!I have a '97 Micra Super S.I just have GA16 throttle body and injectors but I must fit that.With GA16 ecu can they work?My car have NATS and driver airbag with this ecu the airbag will still works?Thank you!
Ed Fusion Motorsport MSC Founder Official MSC Trader Oct 9, 2007 #2 no, plugging in the ecu will not work directly. nats wiring is different
OP OP A Alessandro Club Member (Trial) Oct 9, 2007 #3 Ed said: no, plugging in the ecu will not work directly. nats wiring is different Click to expand... Ok thanks!
Craig Unofficial Member (Gold) Club Member Oct 9, 2007 #4 Is it not just a case of rewiring a few pins? I couldn't find the thread (that I think there is) but I found the two pics that I think the info was based upon: http://www.fusion-motorsport.co.uk/k11/k11_nats.jpg http://www.fusion-motorsport.co.uk/k11/k11_no-nats.jpg Craig
Ed Fusion Motorsport MSC Founder Official MSC Trader Oct 9, 2007 #5 Yes almost. The question was would it work which it wont
OP OP A Alessandro Club Member (Trial) Oct 10, 2007 #6 Craig said: Is it not just a case of rewiring a few pins? I couldn't find the thread (that I think there is) but I found the two pics that I think the info was based upon: http://www.fusion-motorsport.co.uk/k11/k11_nats.jpg http://www.fusion-motorsport.co.uk/k11/k11_no-nats.jpg Craig Click to expand... It's a simple work?The car will sure working?I don't want have problem :grinning:
Ed Fusion Motorsport MSC Founder Official MSC Trader Oct 10, 2007 #7 Its only ever simple if you can fully understand the wiring. Ed
OP OP A Alessandro Club Member (Trial) Oct 10, 2007 #8 If I understand the wiring and I plug the ECU correctly the car will works fine?I will haven't problems with airbag,air con etc...?
Ed Fusion Motorsport MSC Founder Official MSC Trader Oct 10, 2007 #9 no, if you plug it in and it works, it shouldn't affect any of those other systems.
