Have a k11 micra and i need the fusebox layout as last owner has seen fit to remove it and i don't know what i'm looking at if someone has one please drop me a line fast................thanks chaps and chapessess.....
Brake lights - Inside Fusebox - 5th Down on Left (is a 10 amp) Reverse Lights - 12th Down on the Left (10 amp) Side Lights, Number Plate Lights, Illumination - 10th Down on the Left (is a 10amp)
That should cover it, If you need more help Drop me your MSN if you have one, cheers, Darren.
Or you could just do that... Cheers Sonic I think thats covered it...lol
It's different.The layout consists of five downward rows of fuses,3 of which have 7 fuse positions running downwards,the remaining two containing 4 fuse positions running downwards.
1st row:-
Blower motor
Air con
Turn signal
CVT control
Blank
Room lamp
Blank
2nd row:-
Blank
Electronic parts
Abs
Fuel pump
Airbag
Engine control
Blank
3rd row:-
RR Defog
Meter
Cig lighter
Seat heat
Wash
Starter signal
H/lamp washer
4th row:-
Horn
RR wiper
Stop lamp
Wiper
5th row:-
FR Fog lamp
Audio
Hazard lamp
Refer
Problem is the car is in Cambridge and my sister aint great with these things ...........................Hope you can help ................THANKS
Cheers would be helpful mate but i have the layout and i'm non the wiser as to which one controls the rear lamps and the console illumination in this fusebox.........................can some one shed some light PLEEEEEEEZZZZZ?????????
