This is a very capable wideband controller with built in digital gauge and and data logging capability.
It will also log other car sensors such as throttle position, air flow meter, map sensor, air temperature etc.
I paid well over £350 for this a couple of years ago and had it fitted to my turbo micra till I sold it to SirChris.
It worked flawlessly, very easily installed and hooks up to a laptop for either real time data logging (including graphs) or to download already logged data.
I was going to keep this for my next car but i now have a diesel so its no good. Also i need the money for rent.
Comes with Brand New LSU 4.2 sensor as the old one is still attached to the turbo micra till i send chris a bung to exchange for it.
Im looking for £200 plus postage as i need a quick sale
It is the 3E2 model so has all the extras and a digital read out.
From the tech edge website: full details and access to software in the links below
http://www.wbo2.com/3a1/3e1.htm
http://www.wbo2.com/3a1/default.htm
If you have any other questions please ask.
- Inbuilt 4 digit display (this is the primary difference with the 3A1/2).
- Accuracy within 0.1 AFR (Lambda +/- 0.005).
- 10.5 to 19.5 Volt DC operation (up to 3 Amps).
- Uses LSU 4.0/4.2 (Bosch 6066/7057 family) or NTK (L1H1/L2H2) sensor.
- WBlin Configurable wideband 5 Volt output (12 bit accuracy).
- SVout for LD01 display (10 bit configurable too).
- NBsim narrowband (10 bit configurable too).
- 3 analogue 0 to 5 Volt inputs sampled at up to 40/sec.
- 4 thermocouple inputs (can be converted to analogue inputs).
- RPM input from Tacho or ECU for logging.
- PULSE input from VSS sensor or cruise control for logging.
- ALARM output with configurable software triggers, for shift lights, buzzers etc.
- 5 volt output for powering external sensors such as MAP or TPS.
- Auto-cal button, one-touch calibration (with sensor in free-air).
- Free logging software (optional extra feature upgrade available).
- USB Full-Speed (12b/s) virtual serial port - designed for modern laptop computers without RS232 ports. 100% compatible with existing PC software.
- On-board 1 M Byte logging memory downloads via USB and RS232 channels to PC.
