wow i found the problem all right first i did what superls said and connected the wire to ground and got nothink on the gauge???
then i did a test from 1 side of the wire to the other and got nothing???
so i knew then the problem was in the wire. so i took the maf off and induction kit and a few more bits to expose the loom so i could trace the route of the wire then i noticed it the induction kit had been rubbing against the loom and had severed 5 wires in total!!!
anyway resoldered the wires and all done now and gauge works but the green sc light still don't work really can't figure it out. anyway cheers for all your help lads
