Engine Fell Out...
... kinda.
The bolt connecting the rear engine mount to the gear box bell housing completely sheared today! Entire engine then slumped down 6 inches ish....
Am I being dense, or is there actually only one bolt mounting the engine on the rear-passenger side of the engine bay???
If I remember correct the engine mount bracket, this part that connects between cross member and engine block has four bolts. There is just one in the engine mount itself. If that one breaks it should be notable but I can not understand 6 inch, that is actually without a cross member-ish lower.
