CMF_nz_aj
» CMF MemberI did a quick search but didn't see anything quite like this.
The car roll starts instantly & easily, hot or cold.
When cold it's really hard to start, it's a little better when warmed up. It seems like it only catches when the key is turned from start back to ON.
Is there a separate fuse for the ignition circuit (or fuel pump or ECU or something), while the key is in the crank position, versus ON?
Is there a ballast resistor circuit?
This is a JAP spec K11.
