Joel1993 My car is blue... not PURPLE Jun 10, 2013 #1 Just a quick question. Is it possible to swap a coil pack engine to a distributer engine? Is it a straight swap?
skymera Brutal Honesty Jun 10, 2013 #2 Joel1993 said: Just a quick question. Is it possible to swap a coil pack engine to a distributer engine? Is it a straight swap? Click to expand... iirc the coilpacks had a different gearbox, shafts and maybe hubs? Not sure about coilpack ECU
OP OP Joel1993 My car is blue... not PURPLE Jun 10, 2013 #4 Right... Just because later on i am thinking of changing the 1.0l to a 1.3.. The easiest option would maybe be 1.4l because of coils?
frank Club Member Jun 10, 2013 #5 Joel1993 said: Right... Just because later on i am thinking of changing the 1.0l to a 1.3.. The easiest option would maybe be 1.4l because of coils? Click to expand... your 2001 1.0 should be coilpack joel, so you either need a 1.4 engine, or a 1.3 block with your head
OP OP Joel1993 My car is blue... not PURPLE Jun 10, 2013 #6 frank said: your 2001 1.0 should be coilpack joel, so you either need a 1.4 engine, or a 1.3 block with your head Click to expand... Yeahh it is... I think it would be easier with 1.4 engine personally
frank Club Member Jun 10, 2013 #7 Joel1993 said: Yeahh it is... I think it would be easier with 1.4 engine personally Click to expand... they,re pretty rare tho joel
OP OP Joel1993 My car is blue... not PURPLE Jun 10, 2013 #8 Yeahh thats true... Would it just be a change of the engine block to a 1.3 distributer... And of course the ecu
frank Club Member Jun 10, 2013 #9 you would need to fit your head and flywheel to the 1.3 block joel, and just use your ecu
