superls
K10 Tuner
Hi all, i need help, for reasons i dont want to disclose yet, i need the pcd of the mounting holes on the clutch pressure plate, the holes that you bolt it to the flywheel with, ive measured them off the flywheel but ther wern't very nice numbers, and i was hoping someone had this info to confirm my measurements? or maybe someone knows where i can get it?
i googled last night and didnt find anything usefull, i found >>this<< (its a pdf) and it gives a pcd, it gives;
plate diameter as 180mm thats correct
plate inside diameter as 125mm which is correct and
pcd at 224mm but this is not the mounting holes, the best i can assume its the outer dimeter of he pressure plate.
im going to cal at the motor factors one night on my way home, but i doubt they can help me,
can any of you???
cheers scott
can any of you???
cheers scott
