clutch cable adjustment
1111
can you help with this problem . when the clutch is worn out and the cable cannot be adjusted anymore ....is the adjusting wheel on the clutch cable at the end of the thread TOWARDS the front of the car OR towards the BACK ? tried to upload a photo but had a problem ..but if you look at the photo on CLUTCH CABLE by SKYMERA the photo on that is just how my cable is ...cheers
i always adjust mine so that you can just about unhook the cable off the arm without having to slacken the cable off, ie, about 15mm of slack.
that should give you a bite point 1/3rd of the way up the pedal
