i have recently purchased an alarm and to wire it up i need to find which type of central locking it has. is it one of the following...
a: three wire (+) pulse controlling factory lock relays
b: three wire (-) pulse controlling factory lock relays
c: direct-wired reversing-polarity switches. the switches are wire directly to the motors;no factory relays
d: aftermarket door servo driven system;system without actuators in the drivers door but actuators in all others.
e: electronically-activated vaccuum systems
f: one wire system
g: positive (+) multiplex resistor based circuit
h: negative (-) multiplex resistor based circuit
i have an n reg super s with central locking atm if that helps. if anyone can help that would be top banana. cheers all, Tom
f: one wire system
