the last one i got was from a local motor factors ollie (was £25 ish?)
the 1st cat does most of the work apparently, because the 2nd one does,nt get hot enough really
Hi F
... my name is adz.//.... new to the site.... i saw a thread and saw the below advice you gave.
what i wanted to know if that this longer middle pipe removes the middle cat? is it a direct bolt on??
i have a 2000 w reg 1.3 i want to remove the middle cat.... what advise can you offer??
regards
adz
i just bolted the 2 flanges together adz (minus the 2nd cat) but the tube stuck out a little tho iirc, and i had to grind/bash it flush with the flange (or else a couple of gaskets would probably suffice instead) :grinning:
yes adz, my misses,s backbox bolted straight on (there,s a pic in my blog somewhere of the 2 midpipes together) :grinning:
THIS is on ebay.... any good
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=160494849962&ssPageName=STRK:MEWAX:IT
any real power gains though? just replaces the cat with another silencer :/
Please confrim if removing the 2nd cat gives power gains???
this will also be connected to a sports backbox??
