Car not turning over/cranking
So I just had my gearbox out to replace my rear crankshaft oil seal and I've re built everything but when I went to start the car, all the lights turn on but it work turn over/crank.
I'm thinking it's related to the starter motor but I'm not sure and a bit lost as to what it could be? Any suggestions lads?
Same with my K11 just the other day. Stuffed battery. An easy, but not nessesarily a cheap fix. I tested out the battery in my car by using jumper cables from another car.
Sent from my GT-P5210 using Micra Sports Club mobile app
Cheers for the reply mate, I'm going to check all my terminal connections just to double check but I'm going to take my battery into my work tomorrow and battery test it
