Turning over not starting
Hi ,
My 1997 gx Micra is turning over and not starting. I'm getting no fuel. Car was running last week. So far I have changed ecu, checked fuse, checked relay at driver foot well, power at contacts 87 85. No power to fuel pump at all. I've also changed engine control relay in engine bay. Any suggestions? Am I checking correct relays?
OP
OP
Finto_GX
No I can't , that's why I think its not starting. Gave 12v to fuel pump and it works like normal and fuel comes out of fuel lines, tried starting it that way and no luck.. Could it be Nat's?
r-reg-sr
Site Supporter
If you never changed ignition switch I'd do that cheap option first.
nats cuts injectors signal only heard.
OP
OP
Finto_GX
Mine doesn't click but when I try new relay that doesnt click either. I read somewhere that the black and red wire should have 12 v? Mine doesn't?
r-reg-sr
Site Supporter
reason I mention ignition switch is that once it's worn it has trouble dealing with voltage loads and just arcs up.
