can anyone help?
CMF_AwakeN
Hi everyone,
I have a SLX and it seems like its misfiring. while i'm driving sometimes it seems fine for a few minutes, then goes back to the jerky misfire (can hear the revs going up and down). At idle its fine, and drives fine when its cold, but as soon as the engine warms up it starts to misfire. It idles fine when you start it up, but when you come to a set of lights it will die most of the time. I have replaced the spark plugs and fuel filter. Has anyone had this problem before or know how to fix it?
Only had it registered yesterday, it was fine driving there to get it ID checked (about 20mins away) and it was fine a little while after that, but since that its been tempormental.
AwakeN
CMF_Doom
Dodgy electrical connection?
Check battery terminals / clamps are clean and tight, injector plugs etc etc.. Basically anything you changed when building it up..
Blocked injector? Getting air in the fuel line somehow? Did you put small rubber seals in with injectors?
Everything earthed? (other end of neg terminal, fuel pump?)
Do throttle body solder jobby.
Pull dizzy apart & clean?
