camshaft information
micra_pete
Camshafts and Followers
drive
chain
Number of bearings
5
endfloat
standard 0.115 to 0.188mm
service limit 0.24mm
camshaft lobe height
inlet
1.0 Engine 38.005 to 38.195mm
1.3 Engine 39.880 to 40.070mm
exhaust
camshaft journal-to-bearing clearance
standard 0.045 to 0.086mm
service limit 0.15mm
camshaft run out
standard < 0.02mm
service limit 0.1mm
camshaft follower-to-cylinder head bore clearance 0.025 to 0.061mm
CG13DE
Inlet: 222deg - 7.46mm lift
Exhaust: 222deg - 7.945mm lift
CG10DE
Inlet: 196deg - 5.59mm lift
Exhaust: 196deg - 5.59mm lift
Nissan Cube inlet
236deg - 8.46mm lift (lift unconfimed)
GCA3DE - high power version
Inlet: 236deg - 8.32mm lift
Exhaust: 214deg - 7.05mm lift
not to hand, but woah the cams on the 1.0 are simply shocking. I had forgotten how truly 'tame' they are... amazing!
haynes seems to think that the 1.3 and 1.4 cams are the same... but if you know differently then let me know please.. lol cheers :)
The info I had was from the Jap spec CGA3DE engines, which stated 236deg inlet and 214deg exhaust.......although this is from memory, so don't quote me on it ;)
soooooo if thats true, putting a cg13de exhaust cam in will make it faster? although looking at the figures it wouldnt really be noticeable i guess
