ga14de cams in a cg10de has anyone done it or heard of it being done
thanks in advance (Y)
understood just a random idea after seeing cg13 cams in a cg10
so ga16 cams are a swap into the ga14
correct me if im wrong
il have to look into it so, as far as I have seen the heads are nearly identical
They are identical. Only difference between 14 and 16 is the bore/stroke.
ive been told a few different things like the ga16 cams are .5mm more lift on inlet and the same on exhaust,
