Bad boy bonnet
B
benmicrasr
Can you buy these whole?If so where?Or do you weld in a seperate bit of metal then sand and smooth in?Cheers Ben
Definitly custom, there arent many off the shelf parts for the k10 in general! Still, chances are it would be a one off if you got one done.
Also another point to add, there would be alot more work involved on the k10, as the bonnets flip the opposite way to most other cars. The hinges would have to be situated on the opposite side of the bonnet for it to work, as the grille/lights would get in the way when flipping the bonnet up otherwise. I have done it with mine, but needed doing for the look I wanted, works well nwo though, using clio Mk1 hinges. :)
