anti roll bar question
just wandering if I can fit anti roll bars on my 95 L spec or would I have to get wishbones or whatever off one with anti roll bars?
to replace the stock swaybar with an uprated one you simply unbolt the 2 rubber bushes under the chassis and remove the top bolt holding the swaybar to the inbetween union bar piece thing that links it to the lower arm.
swap the sway bars and bolt it back up, easy.
btw i always retap and copper grease all rusty threads to make life easier next time.
A front one will bolt straight on. Fitting a rear one will require the aquisition of a rear axle with the mountings on, the holes for the droplinks are already there in your bodyshell.
Hi, The holes for the drop links are not on the body always, they weren't there on mine and i had to fabricate some brackets to allow fitting, just a warning to check before you get to the point of fitting a rear beam with the brackets only to find you still can't fit it, ideally you need to compare yours to a k11 with the rear roll bar fitted.
