A-M/T CONTROL 20amp fuse
hi everyone,
As you have read my previous post, this is update today I opened the fuse box under head lamp to see, and guess wat I found there is a fuse of 20amps missing, on the label at side it's written A-M/T CONT 20amps and am wondering is that stoping the car to turn engine, I was also trying to figure out what actually is that
Fuse for, before I replace. Any one with similar problems ideas please.
if it was auto and that was the inhibitor switch, then yes the starter would,nt kick in, worth trying a fuse tho i guess
Hi, Frank,
You r right it's for inhibitor switch for automatic gears. The thing now what happened after I did put 10amp fuse
The NATS light turned off but red KEY light kept flashing, engine did not turn, now i don't know once I get another night mare I'll post it.
