I had found this on ebay 5 Door Estate METALLIC STEEL GREY 5995GBP Item number: 230304126840 and The 2.0 L 6-Speed Manual Nissan Primera 20V has Nissan's SR20VE Neo VVL engine with Variable Valve Lift and Timing. please advise if anyone knows different also could you tell me how to post a thread properly thanks
bigger box so new shafts would be needed, and possibly new gearbox mounts looking at...thats even if the box would line up with the k11 engine, which it prob doesnt
no it wouldnt.
im not sure a 6 speed even exists regardless of an ebay auction.
the SR engines are completely different to the CG micra engines and wouldnt be a match at all..
the only gearboxes that would fit the micra engine (and even then not straight forward) are the GA series engines ga14de and ga16de 5 speed.
