1.0 to 1.3
Hey. I know this has been talked about countless of times. But i just want to be completly sure. Want to use a cg13 on my cg10. Dizzy.
Hard to come by these engines where Im located.
So my question is, can i use a cg13 from an automatic just fine in my manual cg10? What do i need? Ecu? Or just time the cg13 retarded?
Maybe you can put your regular 1.0 gearbox and get a better 0-60 due to shorter ratios. You need the 1.3 ecu too. The automatic block is the better one.
