SteveG
Intake n exhaust almost done, suspension next :)
I've drained the gearbox and have plenty of 80w oil to put in, but can't remember how to get the oil to actually go in.
I've removed the speedo drive (and the screw) and have tried:
- a funnel that was slightly narrower than the whole opening
- some 1/4" tube that seemed to fit over the inner nipple type thing that the speedo cable goes inside
both of these options just resulted in the oil seeping out from the top, as if the oil wasn't even trying to go in
I tried with the retaining screw in and out, thinking maybe it's an airlock or something, same result
Tried changing through all the gears (it's in neutral and that's all I've tried it with)
I have some 1/2" tube but it doesn't stretch over the whole opening
I've done it before and have a mostly used gallon of gear oil, so I'm not imagining it lol
Any tips on how to get the oil in? I've tried pouring really slowly, a bit at a time, and it just seeps out no matter what the fill rate
