clutch/flywheel guide
so basically all u have done unbolted the Gearbox and associated stuff and it comes off?
very handy if changing clutch, u dont even need to drom the oil
Nice guide frank.
probably a bit better that the normal way.
Although I'd stick to what I know, drive shafts out, new gearbox oil.bish bash bosh.
bolton_18
on yours, there,s a drain plug and a level plug, on a pre 98 1.0, you have to take the speedo drive out and fill it level with the plastic cog
Do you know if this works on K10s?
Yeah, you can get the gearbox off without removing the driveshafts. I had to take the driveshafts off to get the gearbox back on - I found it difficult to centralize the new clutch with the gearbox in the way.
