Nissanmania WROTE:
"I think that a wild cam isn't going to give you much improvement over a moderate cam because the valve size is the limiting factor in a NA Micra. I've just changed from a wild 300 degree duration one to a 264 degree one and have seen an improvement in top and bottom end with no loss in the mid-range. Go figure.
frank2 WROTE:
"turbo<BR><BR>with the piper (9mm lift) there is about 2 1/2mm more lift before the stock springs get coilbound
