in short no, for starters k12 power steering is electric and tied to ecu where the cg13 ecu has no means of powering it, sensors are not the same between the 2 either, your better off getting the correct engine and if you go bigger than what should be there then you would need ecu for that engine also and you will still have to pay nissan to re programe it unless you get all bits and bobs and then you still have to get them to code steering as there all coded to the individual car, Or completly re loom k12 and run what ever you want in there but at the end of it you wont have power steering unless you can change colum, rack ect to run off pump
