Washer Jets - poor operation
Hi All, the front washer jets on our micra were very poor, tried unblocking them with a pin and soaking them in hot water, next step remove the washer pump to see if this was blocked, but nothing.
Anyway, next I removed the little non return valve from the pipe (in line just before the tee piece under the bonnet), ah hey presto full force washer jets, got myself a new valve and working fine.
Worth a check if your washer jets aren't very good.
I'm having the same problem with mine..
If new washer jets doesn't fix it, i'll be checking that next.
Cheers!
According to his profile, he drives a twister, which is a facelift. As is mine underneath, so it should still be there right?
