Hi all, have signed up to try and find a little more info from those who know these cars best before taking to the garage...
My Fiance has an '03 reg Micra S 1.2 Auto which has recently started feeling a little unhealthy. Symptons are:
I've read a lot about the timing chain bits, which sounds possible (but expensive), but is there anything else we can look at?
Much appreciated for any help anyone can give!
- Fuel economy getting worse - having to fill up weekly at the moment, getting maybe 150 miles out of a tank max currently.
- Juddering at higher speeds - on dual carriageways there is a definite judder coming from the engine that can be felt through the steering wheel, seemingly becoming slowly worse.
- Flat acceleration - obviously it's never been a drag racer, but now at higher speeds you can feel it struggle to accelerate/pick-up as well as it used to.
- Sensor lights - engine light was on, garage just reset fault and said nothing was wrong. Battery light can also be seen flashing on occasionally (usually out of corners or on hard acceleration).
