Belly93 to turbo or new lump :/ hmmm Nov 7, 2013 #1 is the 4spd ma10 engine low enough compression ratio to safely run a turbo from a 1.3 cdti combo on if mappped correctly? @frank @h701micra
Enuo Glorified Electrician Nov 8, 2013 #4 With low enough boost, enough spark retard and a big enough intercooler I don't see how you couldn't.
pork Club Member Nov 8, 2013 #5 Could try what I did, ma10 block, ma12 head, lock the weights in the dizzy, cheap easy simple. You sticking with carbs or going injection
OP OP Belly93 to turbo or new lump :/ hmmm Nov 8, 2013 #6 Would prefer to go injection ive got sime bits and pieces lying about to play with
