CMF_cjke7777
» CMF Memberhey everybody
i just did an engine swap on my micra. now the new one is in and purring nicely BUT the drive doesn't seem to be getting to the axles.
a few notes i have made on the problem to help trouble shoot.
- it doesn't make any diff where the clutch is, nothing happens (no friction point?)
- the car can be rolled in or out of gear (not engaging ?)
- turning one axle doesn't move the other axle (i don't know on these sorts of diffs if thats suppose to happen)
- 4th and 5th gear sorta make a low }rumble?{ when selected and u let the clutch out. ( maybe they are -just- grabbing?)
- the plate was pretty worn but was working before i did the swap so i assumed it should work when it goes back in
- oil levels in the tranny wouldn't make a difference would it?
- it was aligned correctly when installed, but can anything go on backwards during installation?
i tried to give a detailed break down as its usually easier to trouble shoot.
i really need it going, it is being sold shortly
